very cool boost and a/f gauges on S4
Old 01-12-2003, 01:41 AM
Firestarter1984's Avatar
Default very cool boost and a/f gauges on S4
<img border="0" src= "http://members.***.net/shokwave/audis4gauges/completedash.JPG></P>
<img border="0" src= "http://members.***.net/shokwave/audis4gauges/tachinstalled.JPG></P>
</P>
Old 01-12-2003, 09:56 PM
BoostedA4's Avatar
Those are hot, I want some.
Old 01-12-2003, 09:59 PM
they are custom so u can get that for your A4, its gonna be pointless cause the turbo doesnt blow that much boost
Old 01-13-2003, 02:59 PM
Default [Deleted]
[Deleted by Admins]
Old 01-13-2003, 05:50 PM
its not mine, i just found the picture
Old 01-15-2003, 12:09 AM
Mike_post whore's Avatar
the gauge faces on the S4 are slightly different (more greyish compared to the black of the A4). Also if you have a pre 2000 A4 you have the analog clock so this may not work or at the least, would requiresome extra fabrication.</P>
And don't worry about the numbers going to 20 psi...Once you chip you should see a hold of 15psi and spikes up to 17/18 depending on the chip. If you have a 2001 1.8T with the X chip (like myself) you will see a constant hold of 18-20psi--which is awfully high--Also if you get a k04 kit installed, most of them make around 18psi too. The PES T28 kit and APR stage 3 both make about 20-23psi at full blast...</P>
Old 01-16-2003, 10:43 PM
ArtwerkesTT's Avatar
thats pretty clean! i like it, too bad i have a TT.
robb3457
12-09-2008 12:34 AM
jojoenglish85
11-25-2007 03:55 PM
2003silvervette
06-27-2006 03:08 PM
audispeeddemon
08-27-2005 04:10 AM
brkbeats
02-08-2005 11:35 PM
Quick Reply: very cool boost and a/f gauges on S4
