very little heat
RE: very little heat
in other cars i owned, a fully or partially blocked heater core would cause there to be no or little heat. In most cases, I was able to use a LITTLE air pressure to get them unclogged. It could be a good place to start, but I would wait to see what other people say, I don't know too much about my Audi.
Try & bleed the heater core.
There are 2 pipes on that go through the fire wall. On the cool side the hose has a tiny hole in it, you pull out the hose till the hole can bleed air.
You do this with the car up to temp & heat on FULL. You might need to add a little water to over flow tank.
ORIGINAL: audi0104
the battery post the battery is under the back seat i know what to look for but cant find it
