Washer pump location
Old Dec 1, 2007 | 09:34 PM
millenia's Avatar
Default Washer pump location
Hi guys, can any one tell me where the windshield washer pump is in 95 Audi A6. I can see the headlight washer motor but not the windshield washer.
Old Dec 1, 2007 | 10:49 PM
dankhound's Avatar
Default RE: Washer pump location
Not sure on that model, but if its anything like the newer cars youll have to pull the fenderlinder to gain access to it.
Old Dec 3, 2007 | 09:11 AM
Spoke's Avatar
Member
The pump is attached to the washer bottle on the bottom. As mentioned before, it can be accessed through the fender liner or by removing the hydraulic tank, then the water bottle. I have replaced the pump on 2 A6's this way.
When you get access to the pump, there's a top connection to the bottle. Pull this connection out of the bottle, then slide the pump up and out of the bottle. Empty the bottle before you start or all the fluid will drain out.
The pump has a flaw where the bottom seal for the pump shaft leaks and seizes the motor. I have been successful in taking the pump apart, getting some penetrating oil or motor oil and getting the pump working again. Done this twice on one pump and once on another. It's not a permanent solution but will get you back on the road or ready for inspection and may last up to a year or more. Best solution is to buy a new pump.
Spoke
Old Dec 3, 2007 | 11:05 PM
dankhound's Avatar
Hell yeah my wild *** guess in the dark was somewhat correct.
scj
Dec 21, 2010 08:49 PM
Jeffla
Nov 25, 2010 10:09 AM
simonjriley
Mar 16, 2010 06:23 PM
kaodixflow
Jun 25, 2009 07:58 AM
Willfulone
Jan 26, 2005 01:58 PM
