Where does this sensor plug into??
Old Jul 11, 2010 | 01:28 PM
giftmusic's Avatar
Question Where does this sensor plug into??
I have a 1999 Audi A4 1.8T AWD Automatic trans. I have a sensor that is hanging from the bottom part of my drivers side. Can anyone tell me where this goes? Thanks
Attached Thumbnails Where does this sensor plug into??-1.2.jpg   Where does this sensor plug into??-1.1.jpg
Old Jul 11, 2010 | 03:36 PM
aspen79's Avatar
It appears to be the ambient temp sensor. Should be a tab with a round hole in it behind the lower center grille, kind of towards the driver's side. It will "plug in" parallel to the condensor.
Old Jul 11, 2010 | 04:08 PM
giftmusic's Avatar
Cant seem to find it. Is there a pict or diagram you could post that would show exactly where it goes? Do I need to remove anything to see it? Thanks
Old Jul 12, 2010 | 01:16 PM
aspen79's Avatar
Another guy in th shop drives a '99 A4 and looked at his to be sure. Guess the brackets more in the center of the car, behind the center lower grille. There's a plastic bracket that secures the p.s. cooler lines (the big loop of tubing in front of the condenser), that has the round hole for the sensor. It may be missing as these are commonly found broken off. You can either order up a new bracket (shouldn't be too $$$$) or, what I've seen done a few times, is tie strap it to the cooler tubes or something else behind the grille.
You should be able to see it through the lower grille. For access you have to go from under the car or pop the grille out.
Old Jul 13, 2010 | 01:27 AM
giftmusic's Avatar
Thanks so much I found it! Yes it just snaps in very simple sensor. New to Audi Forums and you guys are awesome! Anyway to change the temp reading from Celsius to Fahrenheit? Thanks
ather
Oct 11, 2013 09:53 PM
techh3ad
Aug 6, 2012 04:43 PM
ee99ee
Oct 12, 2011 12:28 PM
fastmav351@yahoo.com
Dec 27, 2010 11:27 AM
werkwitdis
Jun 4, 2006 02:07 AM
