Wierd squeeking sounds
I'm getting this squeeking sound which sounds like its coming from inside the dash when I turn the wheel to the left. It's inconsistent, sometimes its really bad and sometimes I can barely hear it. Now I listen down by the wheel while someone turns it and it sounds like its coming from the CV shaft or boot. Can't pinpoint the problem, any advice would be great.:eek:
RE: Wierd squeeking sounds
Squeaks in the wheel housing can be tough to locate due to the acoustics in the wheel well. Your problem more likly is a tie rod, or lower ball joint. Could be uppers too thou. Try feeling the suspension componants for virations when you turn the wheel. Or use a mechanics stetascope to isolate the point of the noise.
