window motor 99 audi a6
my drivers window will go down but when i try to make it go up it goes up like an inch and very slowly...
whats the problem? and can the drivers window motor and the drivers side rear passenger window motor be swapped? thanks |
RE: window motor 99 audi a6
No the motor is fine, there is a couple of plastic clips that lift and lower the window, the cable eventually starts to crack the platic and binds the regulator. You can buy the window clips at the dealer for about $20.
This only works for the front windows though, the rears you have to buy the regulator. |
thanks ill definately try that, but do i have to go to the dealer? the closest one is quite distant...
is there a place i can order them online? |
http://www.ecstuning.com/stage/edpd/...ategory=Window
This is for a 2.8L A6, you might wanna try searching for your exact car. |
alright thanks alot for the help
ill try the clips and hope that works thanks again joey |
