Window Problem
Old Jan 29, 2009 | 07:09 PM
brojamin's Avatar
Exclamation Window Problem
A few weeks ago my driver side window started making a grinding noise every time it was put up or down then a week or two after the grinding started the window does not move and only makes a very small grinding noise. does anyone know what would cause this or does anyone know how to take a 2004 Audi A4 door off to look and see?
2004 Audi A4 1.8T Sedan
Old Jan 30, 2009 | 01:31 AM
handyvorb's Avatar
Yes your window regulator needs to be replaced. This is a very common problem on Audi's. B5's have a problem with the plastic clips that hold the window breaking. B6's have a problem with the cables binding and jamming, which what you're hearing/seeing. The carrier assembly must be removed then glass removed to be able to take off the regulator.
Old Jan 31, 2009 | 05:16 PM
Prizmatik's Avatar
Definitely sounds like the cable that moves the window up and down is screwed up. I have seen this in other cars, including my wifes '01 B5 A4. You will probably need to replace the whole window assembly, not the glass though.
Ivan_Chokibich
Jul 6, 2009 09:33 PM
codeman4000
Sep 27, 2008 01:02 AM
fluidculture
Aug 26, 2008 01:23 AM
armani1608
Dec 14, 2006 08:00 PM
audidude86
Apr 25, 2006 05:47 PM
