Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
99 A6 leaking oil
Old 11-27-2006, 02:36 PM
mpruitt88's Avatar
Default 99 A6 leaking oil
Can anybody help with my oil leak.
I recently changed my oil and now I have a leak somewhere. It's not from the pan, the drain plug or the filter but their is a lot of oil coming out somewhere.
If I drive a short distance on a cold engine there is virtually no oil spill, but the warmer the car gets, the more oil starts to drip and smoke from the burning oil on the engine block. There is predominantly two main spots of oil, but it drips from everywhere when idle. The two main spots would be just off the sides of the oil pan, but the drips are from above the oil pan somewhere. I cleaned the entire underside and as much engine area as I could with brake cleaner but I can't tell where it's coming from, since it only starts spilling after I start driving and in that case the air flow sprays it all over.
Any ideas?
Old 04-09-2007, 05:09 PM
Default RE: 99 A6 leaking oil
i'm pretty sure that the leak is coming from your valve cover gaskets. on that engine in that car, they are a maen in the you know what. i would bring it to a local garage and see how much they would charge you to tell you if it is the valve covers. if its not that then it might be the nut holding the filter hosing on. those usally come loose on all of the audi models. system fluck. well good luck hope this helps.
Tirrany2000
09-02-2008 08:26 PM
Jc61990
08-22-2008 11:48 AM
darkminotaur
01-03-2008 11:51 AM
Dudek12
01-21-2007 07:23 PM
Quick Reply: 99 A6 leaking oil
