Help needed for newbie!
Hey all,
Im new to the forum. I have brought an Audi A4 B5 1998 wagon (1.8L) I brought it with some problems, however there is one I can't work out. There is a slight shudder/misfire at idle. The mechanic I took the vehicle to has checked the injectors, the coil pack, leads and plugs were changed. I am yet to check the MAF and underneath the rocker cover for sludge build up. Today I noticed a bit of a tappet noise as well. More information regarding the shudder/misfire: Only present at idle When accelerating it disappears There is a slight bit of lag when under heavy acceleration Stalls on cold start Small amount of engine movement at idle The car has 180000kms on it and I have added a valve lifter additive to try and free what I think may be a stuck hydraulic tappet. The mechanic said there was a slight decrease in pressure in cylinder 3 at start up also. I am yet to do an oil and filter change because I would like feedback beforehand. Thanks, I look forward to the response of the forum |
I got hold of a VAGCOM scanner today and found the following codes, could someone decode them for me:
VAG-COM Version: Release 409.1-US Control Module Part Number: 8D0 907 558 B Component and/or Version: 1,8L R4/5V MOTR HS D03 Software Coding: 04001 Work Shop Code: WSC 06325 10 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 01120 - Shareware Version. To Decode all DTCs 04-10 - Please Register/Activate - Intermittent 01165 - Shareware Version. To Decode all DTCs 17-10 - Please Register/Activate - Intermittent 17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting P1564 - 35-10 - - - Intermittent 17967 - Shareware Version. To Decode all DTCs P1559 - 35-10 - Please Register/Activate - Intermittent 01249 - Shareware Version. To Decode all DTCs 26-10 - Please Register/Activate - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 26-10 - Output Open - Intermittent 01251 - Shareware Version. To Decode all DTCs 26-10 - Please Register/Activate - Intermittent 01252 - Shareware Version. To Decode all DTCs 26-10 - Please Register/Activate - Intermittent 00515 - Camshaft Position (Hall) Sensor (G40) 30-10 - Open or Short to B+ - Intermittent |
