p101 and p2188
Hi guys,
I have an Audi A3 2012 2.0TFSI and I have codes 101 and 2188 and the miles per gallon has dropped 2 to 3 miles per gallon. I think that the LT FTRM1 is too high.
abslt tps 12.9%
eng speed 762 rpm
MAF 3.80 LB/M
ST FTRM1 -2.3%
LT FTRM1 -21.9%
I have replaced the MAF sensor and DV valve recently. I can also hear a little noise like a whisper under the hook when I accelerate. I have checked for air vacuum leeks with carb cleaner and nothing happened.
I have also checked hoses to the air intake system and the PCV disk. The PCV disk seems that it is fine. I could not check the hoses that it is the output in the throttle bottle because it is not easy to access.
Do you have any suggestion? I will make an appointment with the mechanic.
Thanks!
abslt tps 12.9%
eng speed 762 rpm
MAF 3.80 LB/M
ST FTRM1 -2.3%
LT FTRM1 -21.9%
Thanks!
spikem
Aug 6, 2015 05:59 AM
Boo_Cocky
May 7, 2014 08:54 AM
Andrew/AWE
Dec 27, 2012 11:18 AM
luxuryimports1
Oct 7, 2009 04:40 PM
