WOW! Exhaust Leak!!! check this thread out
Today, after buyin' a few Bud Ice's (didnt drink any beer yet), I pulled out of a driveway, and stepped on the pedal because there were cars comin', and the next thing you know, I here what sounds like a loud pop. I let off the gas, and when I stepped on it again I realized I have a "Phat" exhaust leak. Initially I figured that I blew an exhaust gasket because I was on the accelerator so much. Pulled over to check and make sure before any more damage was caused, and the pipe/flange that bolts to the turbo was disconnected. I laughed! It was easy to see because I have a cone filter installed and the air box has been removed. I will get my welder out and remove the flange and exhaust pipe and weld it together.
The whistling sound the turbo made was awesome! I have always loved that sound. This whole situation has motivated me to think about an aftermarket exhaust system. I definitely dont want anything loud, although I do love Flowmaster's, but I do want to enhance the whistle sound. As far as the muffler sound, I would like something subtle like the Infiniti G35's. Let me know what you guys think. I will update when I fix the issue. Check out the pictures.
By the way, it happened to my Silver A4 in my Signature.
Here are the pictures.
First I had to mark where the flange and catalytic converter meet when fixed, so that way I didnt weld it on and it wouldnt fit.
Then once I removed everything, I had to grind the edge of the pipe so it would slide into the flange.
Once I did that, I pounded it on tight.
Then I was ready to weld it.
These are the pictures of my welds. I am still learning how to weld, but this will work good enough.
I took a picture of my wifes 2001 Audi's flange because they decided to weld it from the factory. My Audi is a 1997. You will be able to tell a difference between my weld and the factories weld.
Today, after buyin' a few Bud Ice's (didnt drink any beer yet), I pulled out of a driveway, and stepped on the pedal because there were cars comin', and the next thing you know, I here what sounds like a loud pop. I let off the gas, and when I stepped on it again I realized I have a "Phat" exhaust leak. Initially I figured that I blew an exhaust gasket because I was on the accelerator so much. Pulled over to check and make sure before any more damage was caused, and the pipe/flange that bolts to the turbo was disconnected. I laughed! It was easy to see because I have a cone filter installed and the air box has been removed. I will get my welder out and remove the flange and gibson exhaust and weld it together.
This happend to me also only it seperated after the cat but befor the cat flange. it sounds mean.
But my question is shouldnt i be worried about cold air hiting my exhaust valve and burning them up? Because i was considering leaving it that way. but ive been debating with other techs and i keep getting back and forth answers.
