Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
My custom fiberglass enclosure B7
Old 05-08-2017, 06:34 PM
ssuraj83's Avatar
Default My custom fiberglass enclosure B7
Hello everyone.
Here is something I have been working on for some time now.
A custom box fitted for the b7 that fits in place of the storage compartment located in the trunk on the drivers side.
Take a look.
Test fitted the box:
Fitted the front:
Back view:
Made some adjustments:
Tested fitment of sub:
Make sure sub opening is centered:
Now, for the final process.
Some sanding:
Final stage:
Added some carpet on the front.
Installed:
Here are some random shots to show how it sits.
Thanks for looking.
Old 05-08-2017, 06:42 PM
ssuraj83's Avatar
For reference how I have the box secured:
Using these from left to right to mount the box from moving. You can use whatever size you desire.
I cut this one. It was 2".
Here is where the bolt is going. As you see, that's the hole I drilled to fit the bolt.
It goes through the hole here
Old 05-09-2017, 09:00 PM
ssuraj83's Avatar
To be continued............
Old 05-22-2017, 03:03 PM
ssuraj83's Avatar
Working on another.
Old 03-04-2018, 09:47 AM
hichamaziz's Avatar
nice job . good work .
derickonfire
12-26-2008 05:35 PM
ohood
10-02-2008 07:18 PM
_Adrian_
10-15-2006 07:08 PM
Andrewuvm
04-05-2005 01:50 AM
Andrewuvm
04-01-2005 06:09 PM
Quick Reply: My custom fiberglass enclosure B7
