Changing LED For Interior Problem
Hi Guys
I was just wondering if any of you had the same problem. I was trying to install LEDs in my interior and the dome light and the two map lights work fine by the driver and passenger side, but for the 2 map lights at the rear they work but they have a dim glow even though the car is not on. I tried to put one LED and leave the Stock bulb in and that solved the problem. But if i put one in it stays dim both of them any ideas? Thanks in advance.
My LED Do Have Resiters
The LEds I got do have resisters. They are the same ones that i have in my map light up front. But thanks for the reply. I have solved the issue. I put the bulb that I have troubles w/ in one socket and i had an extra 5 led 360 bulb and i tried to plug that one in to the other socket and the dim light was gone. So they are 2 different bulbs and slightly different colors but hard to tell. Thank for your reply.
bluelightbandit
08-10-2007 12:47 AM
