dashboard
Hi everyone! My husband found me a beautiful black 01 A6 but the time and date is wrong on the dashboard and I can't program the radio stations......the car didn't have a owners manual so I'm having a hard time figuring this out....Any suggestions?
TO SET THE CLOCK YOU PRESS THE MODE BUTTON ON THE DASH THEN PRESS + OR -- TO SET THE RIGHT TIME OR DATE.
To unlock the radio with the proper code:
Press and hold (at the same time) the AM/FM and the SCAN buttons until the display reads "1000".
Use the station preset buttons 1,2,3,4 to change each of the digits to the proper code. Button 1 changes the first digit (on the left), button 2 changes the second digit, etc.
Note: supposedly the programmable units were originally coded with either "1111" or "1234" by the dealer. It is quite possible that the code was never changed by previous owners, so if you don't know the code, you can try these.
Press and hold the AM/FM and SCAN buttons again until the radio comes on.
If you fail to give the correct code after two tries, the unit will be locked in "safe" mode and won't change. To try again, leave it switched on for approximately one hour.
