Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Help With Short Shifter
Old Apr 11, 2011 | 02:01 PM
richy's Avatar
Default Help With Short Shifter
I just installed the eBay Short Shifter into my b5 a4 1998 2.8q and wasn't too sure about one aspect of the install. hope you guys can help me out. The main problem I'm having is with how much play the short shifter has when in all gears. It's not noticeable when shifting, but you def. can see how much when just pushing it side to side in any gear. I followed the directions exactly but noticed that all how-to's online and even the b&m are shown using the facelift models.
The one thing i'm curious about is when you remove the OEM shifter from the shifter housing. In the how-to's it shows the OEM shifter pulled out with the two rubber ends around the ball and the white plastic piece that touches the ball. When i tried to remove the shifter, the ball popped out from the white part and i'm not sure if that should happen for the earlier models or was it supposed to look like in the how-to's?
Any help would be appreciated. Please let me know if i might have confused you and need some more clarification or pictures.
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
macspeed702
Mar 4, 2008 10:31 PM
Flip
Jan 28, 2008 10:55 PM
jrock
Oct 6, 2007 11:47 PM
