Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
How to change shifter boot on an '01 Audi A4 Quattro B5
Old 05-25-2016, 09:32 PM
ofStarStuff's Avatar
Talking How to change shifter boot on an '01 Audi A4 Quattro B5
Hello all!
I am looking to replace my shifter **** and boot, but am unsure of how to go about replacing the boot. My question is, do I need to remove the trim piece A or B as in the attached photo? If I have to remove B, how do I go about getting it out?
Thanks in advance!
Attached Thumbnails How to change shifter boot on an '01 Audi A4 Quattro B5-audi.jpg
Old 05-28-2017, 01:32 AM
Evl 01 A4's Avatar
Section B lifts up from the rear and will slide out from under the ashtray once the back is lifted. The boot will disconnect from the **** with downward pressure. There may be pinch tabs on the front and rear but its been a while since i removed mine and I forget. Once the boot is loose the **** with unscrew then the A&B section can be lifted out. The lower half of the boot can be removed from the underside of section B.
MyTinyTT
07-26-2013 12:52 AM
super_sweenqey
07-02-2012 04:53 PM
chickeneater
12-07-2010 12:41 AM
gedas429
08-28-2009 03:19 PM
Quick Reply: How to change shifter boot on an '01 Audi A4 Quattro B5
