AudiForums.com
-   Interior (https://www.audiforums.com/forum/interior-29/)
-   -   It keeps steaming up !!!! A4 front window (https://www.audiforums.com/forum/interior-29/keeps-steaming-up-a4-front-window-160471/)
mrlee Nov 24, 2010 01:59 PM
UK audi
Ok please can I have some help here from any one who knows? I have a b6 A4 soft top, Now the winter has set in ,im finding my front window steams up and does not dissipate, Now, I know it’s a case of turn on the aircon and this will take the moisture from the air and clear the windows, this is the case for every window except the front, I’ve tried every combination on the split aircon panel . Any ideas .
smthkathleen Dec 16, 2010 02:15 PM
Wind shield coating
IN winter there is some windshield coating liquid, once you apply it can with stand for 6 months it will not allow any mist or fog in the screen, just get in in your location available,http://askdoctorwindshield.com/windshield_coatings.php
so that you dont have to get trouble from youe windshield while driing during the winter season, are try for some window heating element, which is being used in Aeroplanes.
mrlee Dec 17, 2010 06:29 AM
Thanks ill have a look at it and see what its like
dublinoh Jan 9, 2011 10:13 AM
Is it possible you have a fan issue...do you feel strong air flow at the windshield.
Also possible you have a small leak in your heater core introducing water to the cabin. Good Luck
dublinoh Jan 9, 2011 10:15 AM
Originally Posted by lmno055 (Post 1275297)
Bo Ru and wow gold Yang set his legs felt limp, the cheap wow gold complete embody trembling full lace wig violently, upset, and wow gold exclusive a knockout faculty to bond to low wow accounts the barely reticent their hearts with imp.
WTF? was too short so again WTF?
DANGER6 Feb 13, 2011 10:48 AM
I was told at the dealership when I bought my car that when that happens you use the "econ" button and it pulls all the moisture out of the cab.
Sorry if you knew that already, I don't mean to insult you.
krazzz Mar 24, 2011 10:57 AM
You could also have a small leak in your heater core causing your windshield to steam. Keep a close eye on your coolant level.
niagara24 Apr 21, 2011 10:34 PM
May not apply but I had a problem with trapped water in the battery tray sloshing into the cabin air intake. Found rubber drain spigot in battery tray was plugged with debris. (2005 allroad 2.7t)
