Any suspension savy Minnesotans out there?
So is there anyone local that would be willing to help me isolate my allroads suspension issue?
Pat found 2 errors when vag'ing my car last night...
Address 34: Level Control Labels: 4Z7-907-553.lbl
Control Module Part Number: 4Z7 907 553 F
Component and/or Version: - 2C1A1 D060
Software Coding: 25500
Work Shop Code: WSC 02334
VCID: 4894524142C1
2 Faults Found:
01769 - Sensor for Vehicle Leveling; Front Right (G289)
27-10 - Implausible Signal - Intermittent
00775 - Level Control System Sensor; Right Rear (G77)
It isn't loosing much air over night, but on the way home today the air suspension warning light came on for a few minutes. It did go off again though. Could my entire problem be just the level sensor(s)? Would that cause the compressor/valve block to simply be contently adding/dumping my bags?
I could really use someone who has a little experience with the allroad suspension and the cluster f*%k that it is. Anyone local want to stop by for some trouble shooting & beers?
So far I have been told from 320 different people....
My bags are leaking,
the sensors are bad,
the valve body is shot,
the compressor is burnt out,
there is a hole in a air line somewhere,
and elves are sabotaging my car...
I cant imagine everything can fail like this in a few days, I need to find out what is causing the issues before I start throwing $200-$2000 at it...
I am in South Saint Paul...
VCID: 4894524142C1
2 Faults Found:
Though very a few OG oxygen Max mild purists have balked at very a few from the much more ostentatious AM mild Retros, Nike has recently taken up the first vibrant pack-driven AM Lights, with much more easy offerings. Continuing this trend, Nike recently unveiled a White/Black/Red Nike oxygen Max Light. Mar 27, 2008 | Comments two |
The White/Black/Red Nike oxygen Max mild attributes a dark Nubuck Mudguard that facilitates a whitened Nubuck/Mesh upper with red-colored accents. although the colorblocking and coloring assortment are simple, the White/Black/Red Nike oxygen Max mild does function a strike of Patent.The White/Black/Red Nike oxygen Max mild is readily available now at Nike accounts.Tech Info:Nike oxygen Max Light
White/Varsity Red-Black.315827-162-All Pics used at [NORT/Recon]More subsequent the Jump
A "fusion" from the Nike oxygen Force one Low and the Nike Zoom Spiridon supra shoes, the "Spiridon" Nike oxygen Force one not merely requires the Black/White/Red colorway from the OG Spiridon, but style and design features as well which consists of the Spiridon's mesh inside the toebox air force 1, tongue, and mid panel, the Spridon's Metallic red-colored Swoosh, and the Spirdon's heel tab.Kicking away their continuing sequence of Nike oxygen Force 1s inspired by traditional operating sneakers and oxygen Max styles www.suprasky.com, Nike recently unveiled the "Spiridon" Nike oxygen Force one Low.
VIA:Filed Under: near to Kix and the neighborhood • Daily work • Sneaker News
luxuryimports1
06-23-2009 11:11 AM
i_baked_cookies
04-25-2007 02:52 AM
