Audi A4 V6 1996 oil leaking!! Help plz
Hello everyone!:-)
I'm having a problem with my car (audi a4 v6 1996) It started leaking oil, its not a lot of oil its just a little bit. I note that because when I'm parked for a while i see oil marks underneath the car. The question is what can I do to fix this problem? Is it a big deal?! any help will be really appreciated. thank you. |
RE: Audi A4 V6 1996 oil leaking!! Help plz
you gara see were is it leaking by it's most pobably that is leking by oil pan but also check the valve cover because the tend to leak by there 2
welcome to the forums! another place to check for oil leaking could be the oil pressure sending unit....does your oil light ever come on?
Hey thanks for your response!
NO! the oil light has never come on. It just leaks a little bit, but I'm not sure where it comes from. Where is the oil pressure sending unit located? Thank you so much for helping me out!! Israel |
the oil pressure sending unit is above/behind the oil cooler (on a 12v 2.8 that is)
