extreme newbie turbo question
Hey i just bought my first turbocharged car, a 98 Audi A4 1.8T Quattro. I've always driven muscle cars, mainly mustang 5.0's, and at the moment don't really have a clue about turbo's. The german guy i bought it from upgraded the turbo when he orderd it from the factory(i gota check through the receipts he gave me to figure out which turbo is on there) and he said it's running at about 12-13 lbs. of boost. I want to get it up to around 18-20 lbs. of boost. My question is how do i get more boost out of the turbo without buying a whole new turbo. My plans were to get a boost controller and upgrade the DV. Anything else i can do and any suggestions on the best types of parts to buy would be greatly appreciated. (i should have what kind of turbo is in the car posted by tomorrow)
RE: extreme newbie turbo question
YOu can get the chip for it. just turning up the boost with a Boost controller will cause you to run lean. However your engine is not designed to handle 20lbs of boost as a daily driver. it can sustian 20lbs fine but i would ony run that high when i'm racing and then turn it back to 12-14 when your just doing normal driving. Or instead of a chip you can get a piggyback system and tap into the ecu and control AF ratio, boost and such from there, its about the same price as a chip
u mean something like a GIAC chip? also wut kind of DV and boost controller would u suggest? i have bout $100-$150 to spend on the DV and bout $300-400 to spend on the boost controller.
my plans for the car- GIAC chip, Borla Exhaust, DV(undecided on type), Boost Controller(undecided on type), APR Snub Mount, Clutch-Masters Stage III clutch, aluminum flywheel, B&M Short Shifter
any other suggestions?
EDIT- another question...any suggestions for a test pipe to go with borla exhaust system??
boost controller is pointless unless you have a bigger turbo. You will run lean and blow your engine. You should save your money and go with a big turbo, you will be much happier. Chipped a4's get old fast.
Flatty
04-14-2008 07:30 PM
FattieJayMack
16
04-18-2007 03:52 PM
