Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
A6 2,7 tdi - turbo fault? (actuator)
Old 08-01-2013, 05:27 PM
Norwegiandude's Avatar
Default A6 2,7 tdi - turbo fault? (actuator)
Hi,
I have the fault code 013128 (Audi A6 2006 2,7 TDI):
19804/P3348/013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction
When i rev it up to 2600-2800 and quickly lift off the throttle it goes down to idle and revvs start to jump up and down violently, over and over again, i have to shut it off to make it stop. And it makes a lot of black smoke.
The car is in limp mode and the malfunction light is on.
I notice that the actuator rod at the turbo is not moving while revving. It should move from the start while reving right? Or do i need to rev higher than 2000 rpm to see it move?
What would you advice me to test/do?
wifesawd
02-05-2013 05:02 PM
nits77
07-23-2008 09:50 PM
erikas3
03-13-2008 12:18 PM
shufti
07-21-2006 12:30 PM
Beerzo
11-02-2004 10:32 PM
Quick Reply: A6 2,7 tdi - turbo fault? (actuator)
