Going bt!!!
Hello everyone im in the middle of going big turbo and i have two turbos in my position to choose from a T3 T04E and a garrett GT2056 which would be best most perfect for the 1.8
There isn't really a "perfect" big turbo seeing it just depends on how much power you want to make and the type of power band you want.
If you want a low cost turbo you might want to check out the Journal bearing turbos from Comp Turbo. |
Mike which turbo is best 400awhp and what all needs is necessary. Im looking for a mid to high powerband. The T04E i have, im hearing is going to spool at high rpms. Not sure how much ill make. For now ill be content with 300. Can my motor spool the T04e? I plan to get
a comp turbo later. |
