How much boost?
Hey, I have a 99 a4 1.8Tquattro tip. Everything is stock except an APR chip and some other usless stuff.
In what range should my boost and Vac.be? I have a boost gauge but i don't know how much i am suposed to have. Anybody know? |
RE: How much boost?
its about 25-30inHG of vacuem and 15psi of boost.
thats what I think should be |
RE: How much boost?
Thanks
RE: How much boost?
i hope you plan on running more boost than 15psi. I run 17psi and i dont even have a chip.
RE: How much boost?
i highly doubt your runnin 17 psi without a chip. do you have mbc or some other mod?
RE: How much boost?
diode for getting past the 14.7psi limit before limp and a mbc. So once again I WIN.
RE: How much boost?
so basically you turned up your boost and didn't change your fuel curve or timing?
RE: How much boost?
thats why i can only go to 17psi and not 20-22. Just waiting to replace the my blown gt28r before the bt setup goes back on. Going back to a ko3 sucks.
RE: How much boost?
are you still on bt programing or ko3 programing?
RE: How much boost?
stock program and injectors
