HP and Boost Question
So im looking at ordering a new turbo setup, FMIC, BOV etc with a steering wheel boost guage pod for my '06 B7. I've heard that the stock block can handle up to 24PSI of boost without doing pistons, rods etc., is this true?! and how much hp can the stock 7spd auto trans (tiptonic shifting) hold up to?! if 24psi is the limit on a stock engine i only want to run 20-22psi to be close to the "explode" limit but still be safe. does anyone know how much i can push on stock injectors, fuel pump etc with out stretching the limits and burning up my trans or blowing my engine?!?! what would the projecting WHP outcome do you think this will be put me up to?! any and all help/ information will be greatly appreciated. send me a PM if you are in Phx Az/ SoCal/ Las Vegas Nv areas if you would like to help or see when its finished. Thanks, Jake
