intercoler
if you mean flashed or a chip soldered on, it depends of you ecu. The older nonVVT cars have small ecus that can only hold on program so if you want more, you need a chip soldered on. If you have a newer ecu, you have have 3 maps flashed on with no physical chip needed. Performance will be the same, the install is whats only differnt. As for the intercooler, forgemotorsport.com or .co.uk with have what you need.
