k04 good deal or too good to be true ?
i found this k04 online today and like the title said. Is this just a good price on a quality part or is it just cheap and should i avoid it ?
http://www.cxracing.com/mm5/merchant...ry_Code=K03K04 |
That's a turbo often sold on ebay. Do a search for ebay K04 and you'll see that many people have had issues with them going bad in 15,000 miles or less.
That is awfully cheap, and does not have a brand. If you're going to do a ko4 spend a little extra for a Borg Warner. It's about $940 for one, price reflects quality. Or... buy if and boost the hell out of it for a couple months, and take it off, check the shaft play, and depending on that junk it and buy another or throw it back on.
that is not a K04!!! thats a K03s pretty much. its a K03 turbo with a K04 compressor wheel and housing.
I saw that on ebay today..
96 06 Audi A4 VW Passat 1 8T K04 Upgrade Turbo FOR 1 8T K03 Factory Turbo | eBay Was thinking of buying it as the turbo on my 1999 Audi 1.8T Quattro has lost boost |
Buy with caution. I can't speak from my own experiences, but from the experiences of others if you plan on running stock boost levels (7-10psi) then it should last for a while. If you plan to run chipped boost levels, longevity will be hit or miss.
Is this turbo K04 same as K0415? I have found a similar one from K04-015 Turbo Audi A4 A6 Quattro & VW Passat 1.8T Turbocharger - Maxspeedingrods.co.uk
It comes at a good price and fits for my 1996 A4, and I am going to place an order. |
Im pretty sure thats the same turbo I used to replace my blown out k03. Its worked well for me and I run 10psi on it. I've had it for about 20k so far. Was a pretty cheap replacement and easy to install.
