PCV Valve
PCV Valve
I'm wondering if you only can get the PCV valve from the dealer. I called all the usual places and haven't been able to pick one up. I even tried looking online and I couldn't find the exact part I was looking for. Is there an after market place I can find one?
There isn't one (at least on the V6) - the early 12v engines have a filtration setup built into the bottom of the valve covers (which you can disassemble and soak in Seafoam to clean), and the later ones just vent through a hose to the throttle body area. No PCV valve to buy, which is why you haven't found them. If you have a 1.8T there may be one - I don't know. It helps to create a signature in your User CP area with the relevant info on your car (year, model, drivetrain, engine, etc) since these cars have so many differences.
Is this what youre looking for:
http://www.worldimpex.com/parts/genu...lve_41825.html
or do you need the puck valve that sits on the TIP?
vtraudt
10-01-2019 08:28 PM
gabeguimaraes
05-22-2009 04:46 PM
