Replaced Factory KO3 with GodSpeed KO3 (Decreased Performance) Help!
Hey guys i have a problem. About 4 months ago my factory ko3 went out on me in my 2003 Audi a4 1.8t quattro causing me to go to the extreme by putting a godspeed ko3 in my car due to low budget. I have heard that these turbos suck but do they really suck so bad it made my car do 0-60 in 11 seconds? I installed the turbo myself and it was easy as pie. But the thought dawns on my every now and then, maybe i didn't install it properly? i was wondering if any one else has had an experience with godspeed ko3?
I know i don't have a vacuum leak cause i replaced every vacuum line in the car about the same time i replaced the turbo and i no longer have a vacuum leak code. Any help appricated |
did you top off the fluid in the hydrossilator?
Originally Posted by ethic
(Post 1430494)
Is the N75 installed properly? |
sorry getting back so late to you guys.
turns out its the MAF causing it to run lean, therefor causing it to slug around even worse. thanks for the thoughts guys
(Post 1430889)
you cant just slap on a different sized turbo and expect it to work out of the box even at same psi. psi means nothing when comparing different turbo's except for how much they can produce. the air flow is what you should look at. aka... 10psi on k03 does not equal 10 psi on k04, sure its same pressure, but the k04 is able to move that pressure at a faster rate for longer period of time. |
