seriously help me turbo kit 2.8l 30v b5
what do i need to make this happen audi a4 b5
Originally Posted by mountainbike91
(Post 1370655)
(Post 1370655)
Believ the manifolds are mirrored so you can swap them around and then make a pipe that connects the 2 and a turbo where the air box is. Route the dp back the way it passenger side exhaust ran. Hook up the oil lines. Add in an fmu with a real wbo2 and gauge and adjust accordingly. This will work fine on 5-7 psi systems which should add another 75-100 hp
Originally Posted by cincyTT
(Post 1371092)
:D |
It can be done for far less than a sc or v8 swap and make more power.
