Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
View Poll Results: A poll
M45
10.00%
M62
12.50%
M90
20.00%
M112
20.00%
forget the audi get a musle car !!!
37.50%
Voters: 40. You may not vote on this poll
Super charger
Old Jan 16, 2006 | 03:55 PM
  #21
kakarot's Avatar
Default RE: Super charger
Okey, I will summrise.
Okey, the PES kit dsadvantages: 1. No possible way to put IC in there without screwing your budget. 2. The M62 Maxes out at 8 Psi and then have to be overdriven which shortens its life. 2. its on top and heat goes to top, heating up he SC and decreasing eficiency. 3. Cost
Advntges: Its easy to change and check oil.
Then mine: disadvntages: 1. It would be hard to show off the car locking like stock. 2. I have no tuning possibilites, so I will try to provide basic Matrix for fuel and Ignton to my best ablity. (I might make a promotion, If person tunes his car he could sell the values back to me for a price). 3. I can only start actuall planing this summer or when becomes warm enough. 4. hard to check oil. 5. I will only provide with posible 3 speed variator [off, on, race fuel]
Advantages: 1. can use IC making more boost, and increasing efficiency, I guess extra 10-30HP. 2. Try to designe an alternative fuell system for the kit so that you could run propane or methane, they are like race fuel but beter 110 to 140 octane, clener and healthier. 3. The variators drive would be the weakest point and it would require changing, so the repair kit would cost like 10-30 buks, easily done. about 0.5-1.5 hours of work. 4. Varitor goes all you lose is boost no damage to the SC or Engine. 5. If the SC oil is same as Engine oil then it would be maintainance free. 6. the kit will provide same reliability as PES.
Note: the variator wont be like 1 second you want power next you dont but it would be like wana race, click click and you taking off. or your gramma in town, and you love your gramma, click click and you are ver near stock power. or you hate your gramm click clck and you are a speed demon.
For the stedy increase of boost I chose to use DV.
Its coming up soon so wait and dont kill your self.
PS I will write some more later.
Old Jan 17, 2006 | 01:08 AM
  #22
kakarot's Avatar
oh ye, why I went with the root type instead the others like centrifugal.
1. The efficiency, the root type is more efficient.
2. its the shape I like and need.
3. ah forget the others.
well right now I'm it the middle of putting together the kit in my mind.
I had idaes, many of them, and well I desided like that.
you will have 3 to max of maybe 6 speeds. each speed will have a dimier so like you switch between them. and each speed will corespond with its boost level. You wont have like increase by 1 psi but more likly by 3-6 psi. so lets say on 2.8 engine you will have 3,7,13psi levels.
On the matter of tuning the Stand alone or more likly piggy back will have controle over it. I will offcouse provide with the basic one, then as I staited before like person actually tunes it, I will pay to get his map, legally ofcouse.
I havent figured out how to make the boost go up and down smothly, but I will get it eventually. I think I will be able to use Piggy to overide some manual controles, so it would be hasle less.
The instalation could be pain in the ***, like 6 hours to install, I will make it as Plug and Play as posible. :-)
Old Jan 17, 2006 | 09:25 PM
  #23
killervenom's Avatar
http://www.wiseco.com/PDFs/Catalogs/...mOrderAuto.pdf
Wiseco will make custom pistons.
http://www.pauter.com/billet_rods.htm
Custom Rods by Pauter they do other things for vw's.
http://www.faliconcranks.com/cw-list.htm
Falicon does custom crank work like lightening, knofe edging, and cryo- treating.
Old Jan 17, 2006 | 09:53 PM
  #24
kakarot's Avatar
dude its so cool. good job. SC that goes high, and pistons that go low. unlimited possibility.
Old Jan 23, 2006 | 09:39 PM
  #25
kakarot's Avatar
well I finished school, I will do SAT and math B regents and I'm done. and the size, fiting, designe starts. Mhehehehhehehehehehehe
Old Jan 24, 2006 | 05:23 PM
  #26
kakarot's Avatar
well did some calculating and thats what I got:
on 2.8L 11.6psi 8psi 5psi
on 3.0L 10psi 6.6psi 3.8psi
on 3.2L 8.2psi 5.3psi 2.6psi
and the kit levels on simulator will be :350HP, 300HP, 262HP. thats on 2.8 is increase of 100%, 70%, 50%. also do not forget Intercooler thats extra plus. and thats at 7000RPM.
well the basics: there is 3 values, high, norm, low.
well I can also make it more speeds but I see no point of that, maybe 4 speeds that be high, norm, low, lowerer. but again no point of that.
and again, the speeds can be higher. and I believe safely at 7000RPM would be 19.5psi that would be 450HP.
and do not forget that usually the top point is at 5500 RPM and with SC it will move further, so lets guess that it would be at 6000RPM then the boost can go high as 25psi and that would bring the SC same 450HP.
and the kit will suport the cryon system, BUT not Nitro, I do not want to burn holes in engine. However If you want to put nitro then be my guess.
Well try making that numbers on PES kit without burning the SC out.
HEhehehehhehehehehehhehe.
I think the RS4/6 will have a compatition from its lower budies.
Thanks to killervenom, now engines can be rebuilded and would be able to run more boost. and initialize full potential of the future kit.
on the note of boost, the kit will suport the propane and CNG, and you would be able to run more boost on stock.
if you have no idea what da hell is propane and CNG I will tell you.:: propane is high octane fuel, the octane value of it is around 110, and CNG is same but diferent its value is 130octane. they are like race fuel but instead of the liquid form they are inserted into engine in the gas form. the advantage of this is that it blends better with air making the AF mix way more stable and presice. On the chemical baiscs, propane has 3 carbon and 8 hydrogen molecules, the CNG has 1 carbon and 4 hydrogen molecues. the Ethane or the stuff they add to the gasoline to make it race fuel has 2 carbon and 6 hydrogen, and thats puts it in the midle of Propane and CNG. however gasoline molecule is around 7 or 8 carbon and 16 or 18 hydrogens.
basicly it ends up to cleaner burn, less polution, long life, less heat, high octane. But what we want is high octane. so that we could run a lot of boost. well see this, the CNG neads to have compresion ration of 15:1 and propane needs 13.5:1. our engines is 10.5:1 that makes a lot of room for mistake or flukes in tuning, less detanation or knoking, less heat and that makes you not to burn your engine through.
Oh the main disadvantage, the tank is presurised to cary this fuels, and the eficiency of the volume to the MPG is not as good as gasolines, that means instead of having 16galons of fuel you can have only 8 galons on CNG and 14Galons on propane. and tanks are heavy. imagine having 50KG bag of potatoes in your trunk all the time. so its only for people who willing. ah another disadvantage if runing the kit right without going too reach the propane looses about 5% power and CNG about 7-10% of total power. and they are reinstated with the boost.
The kit will alow you to run two fuels one or another so that if you run out of one you use another. and thats another advantage.
More coming soon.......
Old Jan 28, 2006 | 05:08 PM
  #27
kakarot's Avatar
Dude, I took it to just get advance regents deploma. I finished AP calculus when I was a junior. I just never before took it before calculus. and thanks to physics, I know some crap of air, liquid denamics. and power transfering loses are some.
and Yes KAKAROT is from DBZ I'm a big fan of that type of a cartoon. where is kiling, blood, superpowers......., like new cartoon Naruto. And I'm fan of SG1, SGA, Batelstar Galactica, Star treck and ofcouse Star wars.
Anywho, I finishing school at well day after tomorow. And SAT was crappy, math easi, at english I was runing out of time a bit. and the Essay was as easy as hell, like for 9th grade.
any way soon I will need people with diferent type of engine to be my giny pigs, becouse of diferent style of the head, the fan (some models is powered by belt the half), and the AC.
It may be required to lose the fan powered by belt.
I really dont know if I should post pictures of it before it comes out. so I will hold them a bit more. or not.
the whole system is almost complit, in virtual reality. NOT TO SCALE. and the hard part comes, parts. and the actual price, and tuning which I will do scientificaly.
But besicaly the kit will include evrything to be instaled like plug & play. But the thing is it will have to be instaled from the bottom. which is kind of dirty.
What I will requre from you as a coustomer: the code of the engine, what heads you have 12V or 30V, displacement, and what level of output you planing(realistic). and maybe some more.
the options whould be, Pigyback, Intercooler, repair kit, clutch update, ATF update, injectors, pistons, etc...
The work you will have to do: Instalation (duh), people neer me would just come to me and I will instal, but that person will have to buy me deaner.
the tube cuting, the tubes for air will have to be cuted under your requirnments, for each model diferntly.
and maybe some more simple stuff.
Old Feb 5, 2006 | 05:32 PM
  #28
kakarot's Avatar
Well, I thought about the kit again, and came up with a problem, mostly asociated with space. Unless coustomer wana lose the AC and gain the sleak sleeper, the kit is discontinued. However coustomer if wana can get it, when I'm finished, he can use 60 AC= windows down and going more that 60MPH.
New thing: The kit is continued in development, still will have all the same options and numbers, but now its gona be placed on top. BUT its not gona be made like PES kit where SC sits right on top of the manifold, couse it would be called stiling. The kit still would be able to switch speeds, use Crayon, have IC. But now there is no worry of drowning.
The kit still gona use the M90. There is another place where I might be able to squase the whole contraption.
This is what it could have been if no space was a problem.
Old Feb 8, 2006 | 06:52 PM
  #29
I'd personally would rather not lose my a/c. Also i love the idea of the s/c on top of the motor, and stealing would be to buy his and copy the exact manifold and use a m62, all you have to do is design the adapter plate differently and not to mention you have a m90 so that would make the kit completely different anyways. a cool thing to do is laser etch the adapter plate with the your company logo or Supercharged, or even just M90. just a few ideas
Old Feb 8, 2006 | 08:35 PM
  #30
kakarot's Avatar
If to use PES like manifold and adapt it to the M90, then the way to change the boost would be to change pulles. do you really want to do that.
And it would be easier just to take the whole manifold out with the bottom part and put SC there, but its still expensive becouse of coustom work.
and yes I do not want to lose AC, here in NY it becomes hot sometimes and I sweat really nasty. and besides I already charged my AC about 75% so no way I'm gona tough it.
my new idea is diferent. The PES kit that is on top of the motor is expensive, couse coustom manifold. so no, i'm not gona do like them.
my idea is to be on the side of the engine, its lower and M90 will definatly fit.
The In and Out IC tubes will run just benith it so it actually cute, the huge cone filter including MAF sensor would be instead the airbox. I will try to make a dummy kit soon, as soon it becomes warm oustise, so lets wait and see.
The diference: M90 is the same length as M62 SC however M90 is a bit wider and higher, not by much.
The base Idea of my kit would be: power on the buck. You will get as much power as I can provide for as little as I can to sell. cheap. Imagine having N02 bottle in your car and be able to use it all the time and unlimited quantaty. Ye sound good, well thats what I'm trying to do.
