Dremel Drills/BITS?
Old Jun 3, 2008 | 09:15 PM
Dj Spiel's Avatar
Default Dremel Drills/BITS?
Does anyone know anything about this stuff?
I need am going to drill my case for the watercooling parts I have purchased...they should all arrive Friday.
Anyone recommend a good drill along with the snap-ons?
I was looking at this
697-06 just for the bits
http://www.amazon.com/Dremel-697-06-.../dp/B0000C6DZ6
Is that ok? If it is..what brand drill should i get?
Old Jun 4, 2008 | 12:58 AM
achTTung's Avatar
Default RE: Dremel Drills/BITS?
if you're shopping for dremel tools, wouldn't you use them with a dremel?
Ive never really used a dremel except for porting 2-stroke cylinders. Drilling and stuff I've always used a drill, either a cordless, or a big drill press, which I can no longer live without (spoiled hardcore).
Hell, now I run a waterjet, I a cut any size hole from .050" to 48".
If all you're doing is putting a hole in a PC case, it really wont matter what you're using. It's not hard metal, and its not super thick. Cordless drills are cheap (or use the dremel if you have one), and you can buy single drill bits at most hardware stores, just pick up the one you need.
Old Jun 4, 2008 | 01:04 AM
Dj Spiel's Avatar
kool thanks!
Old Jun 4, 2008 | 01:06 AM
qUaTtRoA4's Avatar
if you end up buying a dremmel, get one that plugs into the wall...I had a battery powered one, and it ran out of juice quick....
what size hole/s do you need to make?
you could prolly use a drill and a drill bit....
Old Jun 5, 2008 | 02:59 PM
Whiplash's Avatar
Dremels are great, I use mine all the time. But it sounds like you just need a cheap drill...
carparts123
Aug 17, 2013 07:40 PM
Bambs88
Jun 18, 2013 02:39 PM
jeepthrills
Dec 14, 2011 11:46 PM
gf8stiv3
Jan 17, 2011 08:56 AM
needragr
Feb 3, 2010 06:21 PM
