drug testing
If i get drug tested and take a detox can they see that ive taken a detox cuz a buddy of mine said that his friend took a detox before he got tested and when his test came back they said he was clean but they found a cover up or something like that. neone care to chime in.
depends on how they're sampling, and what they are testing for. If its a urine test, don't be a dolt, STOP USING for a few weeks and your body will detox itself.
If it's hair, unless you shave it ALL (all over your body, princess) off, they will be able to tell your entire drug history over the entire length of time your hair was growing while you were using.
To answer your question...
Depends on how much $$$ they wanna spend on the test. Deep pockets and, yes, they can tell what yu had for breakfast that morning. So, if it's a local company, you may be OK. If its a multi-state corporation, you might wanna go with my 1st piece of advice. Gub'mint, and/or multi-national corporation... Shave, EVERYthing, EVERYwhere, THEN, follow my initial advice.
most detox products are a waste of money. You cud prolly google your way to the poorhouse and a failed test, pretty quickly, if you want.
Take me, for instance, I started cleaning up for my next drug test sometime back around 2nd, 3rd grade. Nearly 40 years later, I am pretty sure I'm clean!
not sure what your local laws are..but in cali, they are only allowed to test for illegal substances. the only time they can test beyond that is if it's a court-ordered drug test (but if that's the case, you've got bigger problems to worry about)
i've known people that have failed tests using detox products. from what i've HEARD, quick-fix is the safest option. although i have absolutely no first-hand experience. :X
