AudiForums.com
-   Off Topic (https://www.audiforums.com/forum/off-topic-5/)
-   -   Ford van and serpentine belt slips off! (https://www.audiforums.com/forum/off-topic-5/ford-van-serpentine-belt-slips-off-95898/)
spectrum Mar 22, 2008 11:02 AM
I am having a problem where the serpentine belt will slip off after short periods of driving. The belt brand new will come off after say 200 to 300 miles. It first started after I had the engine replaced with a used one. Van motor is a ford 4.9l inline six. What could cause this? Since I have replaced the tensioner pulley, starter and smog pump. I use the van for work and have been burning through belts been under the hood more than enough times. Thanks for any replies
originalspanksta Mar 22, 2008 12:01 PM
RE: Ford van and serpentine belt slips off!
get a straightedge and check the alignment of your pulleys, one is probably off a little, or is bent and wobbling.
spectrum Mar 22, 2008 12:23 PM
Ok, If off how would I adjust? Washers. I think all pulleys are spinning straight I'll check again
karguy427 Mar 22, 2008 10:47 PM
Assuming all the pullys are in alignment,I think you may not have enough tension on the belt. Tighten it up.
acamillo Mar 23, 2008 12:27 AM
Do ford's have tensioner pulleys? If so that might fix s***
spectrum Mar 23, 2008 02:26 PM
ORIGINAL: acamillo
They do I think i'm going to replace again maybe defective.
acamillo Mar 24, 2008 01:33 AM
wow i guess i should have read a little more closely, oh well, good luck with your belt
