How much HP does a turbo timer add?
So, I was working yesterday in Groton, CT, when I spied a bright red Accord that was running in the parking lot. The windows were pretty dark, but there was no one in it. I looked it over and noticed a turbo timer and boost gauge, so, I thought that it was a custom turbo Accord. Boy was I wrong. It did have the timer and gauge, but no f*cking turbo at all. I mean, how lame can you get? He took off out of the parking lot and sure enough, it was just motor, not even a hint of any boost. Hit the rev limiter for almost three full seconds before he shifted, too.
RE: How much HP does a turbo timer add?
lol maybe he had one of those leaf blower option on his car that is turned on/off by a big red toggle switch under the dash. :D
I would have heard a leaf blower!
Nooo! He hit rev limit because he was trying find and flip the switch. :eek::D
Im pretty sure the gauge was probably a tach since most Honda cars WITH MANUALS come without a stock tach :eek:. Also you dont need a turbo to use a timer, same concept applies letting the engine cool before shutting it off, but only needed if you are maxing out the engine and creating alot of extra heat like a road racing car
Maybe hes preparing for the big setup:)
ORIGINAL: A4speed Maybe hes preparing for the big setup:) And don't forget the neons, cut springs, and wings! |
so there is one true way to tell if he is rice or not, did he have painted drums?
ORIGINAL: cincyTT Im pretty sure the gauge was probably a tach since most Honda cars WITH MANUALS come without a stock tach :eek:. Also you dont need a turbo to use a timer, same concept applies letting the engine cool before shutting it off, but only needed if you are maxing out the engine and creating alot of extra heat like a road racing car that might be the case if he wasn't a ricer (and no im not calling him a ricer cuz he drives a honda, its cuz he hit the rev limiter right after starting his car) |
ORIGINAL: cincyTT Im pretty sure the gauge was probably a tach since most Honda cars WITH MANUALS come without a stock tach :eek:. Also you dont need a turbo to use a timer, same concept applies letting the engine cool before shutting it off, but only needed if you are maxing out the engine and creating alot of extra heat like a road racing car |
