Last Night.
Old Dec 2, 2007 | 01:49 PM
CrAyZe's Avatar
Default Last Night.
Last night, i was driving about 40 - 60 km/h and i looked down to grab a cd. I hit the curb and blew both tires and bent a rim on the right hand side of my car. I just want to know the chances that i bent the axcel of the car?
Old Dec 2, 2007 | 02:13 PM
SAudi's Avatar
Default RE: Last Night.
if the car goes straight your probably good, although you may have to replace a wheel bearing in the future, if your wheel looked pushed in chances are you bent a control arm which for both sides is atleast 1000 with parts and labour. but if you hit head on straight your probably good and only fvcked the tires and rim.
Old Dec 2, 2007 | 02:15 PM
CrAyZe's Avatar
thank goodness, yes it was straight on! i was so sad. everything looks fine actaully except for 2 flat tires and a chunk from where i hit the curb out of the rim..
Old Dec 2, 2007 | 02:19 PM
SAudi's Avatar
well in that case your probably going to need a new rim, maybe both and 2 new tires.
Old Dec 2, 2007 | 02:22 PM
kriptonik's Avatar
An excuse to go for aftermarket wheelsif you haven't already.
CrAyZe's Avatar
ORIGINAL: SAudi
is it possible that the axcel could be fvcked? and i just cant see notice it.. or most likely just the rims/tires..
Old Dec 2, 2007 | 02:41 PM
Amze's Avatar
failure...!
Old Dec 2, 2007 | 06:09 PM
SAudi's Avatar
ORIGINAL: CrAyZe
ORIGINAL: SAudi
i highly doubt it unless the axle hit the curb in which case it would definelty have some sort of visible damage, worst case if anything would be that the cv joint would fail but like i said since you hit it straight on chances are rim and tire damage only.
TurboMike
Nov 19, 2014 05:23 PM
SleepinS4
Jan 17, 2011 02:02 AM
kriptonik
Aug 17, 2010 09:27 PM
chaos92287
Oct 15, 2006 11:47 PM
CheckMyVitals
Sep 12, 2005 02:51 AM
