need help w/ Madden ASAP
ok.. im getting my a$$ handed to me by my younger brother..
im constantly getting beat on the deep pass - like wide out streaks, no matter what.. i've got nickel - man coverage... & shade the safeties deep too... but still get beat by the looooong pass [:@] any d-fensive ideas / tips... [&o] |
RE: need help w/ Madden ASAP
Easy Play, bump and run with the corners then Play a cover 3 or cover 2 with LB zone pressure. Also you can tap the right controler stick up for Pass commit right after the qb hikes the ball. Also try turning the passing level up to all madden the streak doesn't work.
Jason |
Trying using a team besides the Raiders
THANKS :D
sweeet. ok..I'll use the bump & run... (I was sending them back for pass coverage..) should I use the LBs in zone pressure like hook zone or the deep zones... |
or the Detroit Lions, Arizona Cardinals, orHouston Texans ;)
ORIGINAL: socaljoe Trying using a team besides the Raiders SACRELIGEOUS JOE.. be careful.. people know Im from SoCal. they might think I like the Raiders [:@] [:'(] |
| All times are GMT -4. The time now is 11:06 AM. |
