timing belt replacement
Hey i got a 1999 a4 quattro 2.8 manual with 87k on it. I am thinking about getting my timing belt replaced soon. I called around and this one place said I should definitely get my water pump, timing belt, and something else (i cant remember) all replaced at the same time. So it went from just spending bout 800$ on replacing the belt to 1700 to replace a few other things including the belt. Is this completely necessary? Or can I just get by with getting the belt replaced?
Thanks for any suggestions
A typical cost of getting the timing belt (kit) package done will run you $800 to around $1,500 usually. There are different kits but you want the most complete kit including all belts, timing, a/c, p/s belt, tensioner and rollers, water pump and thermostat. Also around 3 liters of G12 coolant that they need to refill since you have to drain it. Visit ecs tuning to get an idea. Usually for the timing belt kit and coolant will run you around $300 so as you can see it is a labor intesive job. You can save a lot of money knowing a good buddy with mechanical skills and buy a 6 pack for them as well.
This can also be posted in the A4 B5 section and you will get some hints as well about the search button just to warn ya . Good luck!
I was quoted around 1k for mine at a local indie Audi mechanic but the stealership was $1,400. One guy on here, can't remember was quoted around 2k for his. I would say for what he was quoted from just a little extra in parts and the damn front end is torn apart anyhow, a jump to $1,700 is quite stupid so I would head somewhere else.
Head...That pic in your sig is sweet by the way. If I didn't do all smoke that would be it .
Ok i talked to my mechanic friend and he said he'd do it for 725 for just replacing the belt and the accessory belt, and coolant change. That's it though. He told me the tensioner and rollers, water pump and thermostat doesnt really need to be replaced...He said the main problem with my car or what the factory says is the timing belt needing to be replaced. So my next question is it not smart to just do the two belts and coolant change? Or should I definitely do the water pump thermostat ect... all at the same time?
Do the WP, thermostat, and tensioner/rollers now... If they go later you'll be looking at the same $800 or more since you need to take it all apart again.... Better to do it now. Should only be about $150-$250 more in labor plus the parts.
ok thanks man. I just got a better deal at a different shop, they said they would replace everything including wp, thermostat etc for 1100 for everything. The only thing they said was that i wouldnt have to replace the rollers unless they are truly in need of being replaced and if they are it would only be 100 more. Funny I first called an M service shop and they wanted to charge me 1750 for everything...its always good to look around...
Timing Belt
OE Updated Tensioner
OE Tensioner Roller
OE Idler RollerCamshaft seal
Crankshaft seal
Graf water pump with gasket & o-rings (Metal Impeller)
Behr OE Thermostat with O-ring
Conti-Tech A/C Belt
Conti-Tech P/S Belt
Conti-Tech Alternator Bel
2) 1.5 Liter bottles of G12 Coolant
This is the kit I just had installed on my car along with the turbo and the mechanic said it went together smooth as butter. He charged me $400 for installation of all the above parts and the cost of the kit was $300
Total - $700
Here is a link to the ECS Tuning kit
http://www.ecstuning.com/stage/edpd/...productID=5633
Just read that this is for a 2.8 so here is the proper kit for your car .....
http://www.ecstuning.com/stage/edpd/...productID=7442
