RS Model Line Audi RS4 and Audi RS6..Pure race-car performance technology applied to the comfortable ride for which Audi is known
APR Presents: Audi C6 RS6 5.0 TFSI V10 ECU Upgrade!
Old 12-17-2010, 07:17 PM
Arin@APR's Avatar
Default APR Presents: Audi C6 RS6 5.0 TFSI V10 ECU Upgrade!
Product Page
APR is pleased to present the ultimate ECU Upgrade for the Audi RS6 5.0TFSI V10 Twin Turbo.
After months of long nights and many hours of testing, development and more testing, we are
pleased to offer you an ECU recalibration that is second to none. APR's extensive research and
development provides you with a powerful ECU Upgrade with no loss of drivability or reliability.
Expect tremendous increases in power and torque across the entire power band, improved
throttle response and a smoother, more powerful top end.
The RS6's engine management presented new challenges to the Engineering Teams at APR in the
form of new control strategies for torque management. Significant time was spent researching
these new strategies to properly request more load and therefore more boost in the lower end
of the power band. The results were simple, a torque curve that crushes the competition and
delivers a rush of power like no other in the industry.
For safety and shift quality concerns, APR's Engineering Teams spent even more time determining
appropriate levels of torque to deliver in first gear. As such, maximum boost pressure is lower in
1st gear than all other gears. This resulted in the most powerful yet reliable software possible.
The Audi RS6 5.0TFSI V10 Twin Turbo ECU Upgrade is an expertly recalibrated engine control
strategy that remaps boost, timing, air fuel ratios and other engine management paramaters
to provide smooth and reliable power as if intended by the OEM. APR's ECU Upgrade is developed
to work within the OEM and Tier 1 Supplier specifications for engine component stress tolerances
and performance specifications. APR's ECU Upgrades are available in octane specific versions to
allow you to take full advantage of the fuel quality available in your area.
Stage I ECU Upgrade
Not only does our Stage I ECU Upgrade give you higher peak numbers of 741 horsepower and
779 ft-lbs of torque, but also gains of up to 237 horsepower and 299lb-ft are available at lower
RPM's with 104 RON! APR's ECU Upgrade is the best power per dollar modification for the new
5.0 TFSI and gives it just the extra edge these cars lack from the factory without pushing the
limits. With factory like smoothness and drivability APR's ECU Upgrade will fill the void in an
otherwise excellent car.
APR Stage I ECU Upgrade Calibration Report
Stock
As Reported by Audi
572 HP
480 TQ
Stock
As Measured by APR
597 HP
507 TQ
98 Octane RON
665 HP
716 TQ
174 HP @ 4350 RPM
237 TQ @ 3600 RPM
104 Octane RON
741 HP
779 TQ
237 HP @ 4550 RPM
299 TQ @ 3600 RPM
http://www.youtube.com/watch?v=2TQBXvx7V48 http://www.youtube.com/watch?v=Tx0iW9FpyvA Application Guide
All C6 RS6 5.0 TFSI V10 Engines
Directport Programmed through the OEM ODBII Port - ECU does NOT need to be removed!
Currently Single Program Only
Please contact a Local APR Dealer for Pricing!
Arin@APR
06-20-2011 05:35 PM
Arin@APR
01-21-2011 12:03 PM
Arin@APR
12-16-2010 11:54 PM
Arin@APR
12-15-2010 04:52 PM
Arin@APR
11-12-2010 08:53 PM
Quick Reply: APR Presents: Audi C6 RS6 5.0 TFSI V10 ECU Upgrade!
