0-60
Old Apr 17, 2006 | 06:48 PM
Leto's Avatar
Default 0-60
I recently bought an '02 S4, and decided to test the 0-60 time (6.5sec for an auto, right?) myself. With just myself and a 3/4 tank of gas, I could not get it under 7.4 seconds... It just feels like a really really long time before the turbos kick in at ~3000rpm, and in my opinion, the car keeps the gear in 1st waaay past the torque curve, into redline. Maybe the best 0-60 is done by tiptroniccing it into 2nd earlier? Any suggestions?
-Ivo
Old Apr 17, 2006 | 06:57 PM
scarzie's Avatar
Default RE: 0-60
You should be just under 6 at least... Check your TBB and DV's and all of you boos lines for a boost leak.
Old Apr 17, 2006 | 07:00 PM
Leto's Avatar
Default RE: 0-60
I assume you mean "under 7" (I have an automatic)
Old Apr 17, 2006 | 07:01 PM
sooks's Avatar
Default RE: 0-60
no..under 6... an s4 manual or tip run mid to upper 5's... maybe 6 or 6.1 if your a bad driver..
Old Apr 17, 2006 | 07:02 PM
sooks's Avatar
Default RE: 0-60
you are talking about an S 4 right...not an A4
Old Apr 17, 2006 | 07:08 PM
Leto's Avatar
Default RE: 0-60
How can you be a "bad driver" in an automatic? It's just flooring it, no? I can see that if you're not proficient with a stick, the shifting can influence your times.
Also, the 1st to 2nd shift at 6000+ rpm is really "smooth", I had expected a shiftprogram that would just switch gears quite hard.
(yes this is an S4)
-Ivo
Old Apr 17, 2006 | 07:25 PM
sooks's Avatar
Default RE: 0-60
i was referring to manuals for the bad drivers thing... but an s4 shoudl run under 6 seconds... if not..youve got problems.. probably a boost leak... or maybe bad 02 sensors??
Old Apr 17, 2006 | 07:36 PM
Leto's Avatar
Default RE: 0-60
OK, so how would I go about testing all this? I used to own a Ford where _everything_ in the engine compartment is easily accessible. swapping plugs would take me 15 minutes!
How do I test for faulty O2 sensors? I don't see the MIL on. Not even a clue how to start checking boost lines or diverter valves.
Old Apr 17, 2006 | 07:43 PM
sooks's Avatar
Default RE: 0-60
well first thing..do you have a boost gauge in there... (just a stab in the dark.. but prob not...) if you do..just check what your boost levels are...
Old Apr 17, 2006 | 08:00 PM
Leto's Avatar
Default RE: 0-60
no gauge, just stock
