AudiForums.com
-   S Car Model Line (https://www.audiforums.com/forum/s-car-model-line-13/)
-   -   01 S4 loosing coolant, no smoke, no overheating (yet) (https://www.audiforums.com/forum/s-car-model-line-13/01-s4-loosing-coolant-no-smoke-no-overheating-yet-98696/)
My_01_S4 Apr 14, 2008 05:57 PM
Sorry about a long post but I don't want to leave any critical details out...
01 S4 w/ 150k. I'm the 2nd owner but from the carfax records I know it's been well maintained (all on time and dealership serviced) but now I'm loosing coolant. Not while driving (that I can tell) but after I come to a stop and shut off the engine. I don't see any leaks right away but after it's cooled ~ a cup can be found under the car.
I also checked for a pool of coolant after my drive to work this morning (4 mile drive) at 1:00 pm. During the drive in, the car was barely warmed up (coolant was warm but oil temp was still not warm) and I found there was no coolant underneath. Yesterday when the car was fully warmed after driving 15 miles to a friends home I had a puddle underneath when I came out to drive home. When I got home, I let her idle for a couple of minutes and had no puddle underneath. Later last night I went back out to check (an hour or more after shut down) and there was a new puddle of coolant/water.
I don't detect any sickly sweet coolant smell when driving which I expect w/ a typical coolant leak so I'm hoping this is a known error that's easy to diagnose and cure.
After I posted the above on AZ's forums someone suggested the Secondary Coolant Pump. I found an Auxiliary Water Pump in the Bentleys (item 5 in the enclosed diagram) but I'm wondering if this is truly the cause (before I start digging into it) or if it could be something else?
I understand it takes 2 hours to R&R the pump. If I R&R this item, what else is accessible enough that I should go ahead and replace it? Plugs? Timing Belt? My leaking Driver Side Valve Cover Gasket?
Last but not least I heard it is possible and definitely easier to R&R w/out removing the intake manifold however I have not found any hints on how to do this proceedure w/out removing the intake manifold. Any idea's on how to do this would be greatly appreciated.
TIA
