2004 Audi S4 Oil Change Procedure?
I have been DIY oil changing all my life.. This is my first german car, and just want to get any heads up i might need to know.. I have purchased the proper cartrige type Mann oil filter, just would like to see if anyone has a procedure of where everything is located on these cars, or anything else i might need to know. I have been a GM guy all my life, and just need to know the things like where the filter is located, ect. ect. Thanks in advance!
RE: 2004 Audi S4 Oil Change Procedure?
ORIGINAL: sweeds4
im sure some B6 guys will eventually talk...
how do u like the Audi complared to the GM's???
ORIGINAL: lowridin88
Ok cool.. My biggest thing is i have never messed with one of those cartridge type filters.. or where they are even located.. Did alot of searching the net and found nothing
a ford wrench will get the top off of the filter housing; if you need a new o-ring, it should come with the filter. drop the plastic "skid plate" on the underside and the plug is right there and uses a hex key buti can't remember the size off hand. somewhere around 10mm i think.
Well i got the oil changed last night! Thanks for all the help. Not sure why audi cant put that drain plug in an easy to reach location like every other GM vehicle i have ever worked on. Oil filter on the other hand was pretty sweet being right on top like that.. All in all it didnt go too bad
