Originally Posted by Lazydog
(Post 1415723)
It has more to do with direct injected motors. Because the fuel doesn't pass over the valves they do not get cleaned regularly.
I can tell you that my 2007 S8 with 48k miles is back at the dealer, for the 3rd time.
1st time - Check engine light went on, diagnosis=faulty manifold, replaced under warranty. 2nd time - Check engine light went on after 24 hours; diagnosis=carbon deposit and faulty fuel injector #2, replaced and repaired under warranty. 3rd time - Check engine light went on 6 days after I had it back; diagnosis=Audi wants all fuel injectors replaced under warranty. Wonder why?:p I hope this solves the issues. I am a very spirited driver who only burns Mobil or Shell and I am not going to be refused my therapy because of some carbon build up...:D |
Originally Posted by Incaico
(Post 1421644)
Had same issue
Turns out there was always in the gasket around the spark plugs and oil was hitting into the spark plug chamber.
if you remove a spark plug do you see oil? |
Originally Posted by Mys6
(Post 1516186)
Carbon build up can be a common issue on these direct injection engines. It's recommended by Audi to use the fuel additive every few gas tanks to clean the carbon off ( part # G 001 780 M3 ). If it gets too bad the intake manifold will need to be removed and carbon cleaned off by hand... it's a process... all in all probably take you about 6 hours.
