AudiForums.com
-   S Car Model Line (https://www.audiforums.com/forum/s-car-model-line-13/)
-   -   Abs and airbag lights? (https://www.audiforums.com/forum/s-car-model-line-13/abs-airbag-lights-159707/)
archangel1st Nov 9, 2010 01:01 PM
Just had the rear suspension redone and now I have my abs, traction control, and airbag lights on. I got the traction control to go off. But what about brakes? Bled the brakes to, so how do I get the brake light off? And i have not a clue about the airbags.. I have heard stores about using vag com and testing the airbags and they have deployed... Don't want that to happen lol. But yea any ideas?
2001 b5 s4 2.7 biturbo, full apr chip
archangel1st Nov 9, 2010 09:04 PM
plugged in vag-com and this is what i got.
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 15: Airbags
Controller: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06435
1 Fault Found:
01589 - Igniter for Head-Airbag: Passenger Side (N252)
32-10 - Resistance too High - Intermittent
Address 01: Engine
Controller: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 00000
2 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0001
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
00778 - Steering Angle Sensor (G85)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 06435
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 07228
2 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 15977
Shop #: WSC 07109
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
No fault code found.
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06435
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 06435
End --------------------------------------------------------------------------------------------------
any1 mind telling me what they mean? n how to fix?
Oh yea i need to replace my tie rods and axle on passenger side so i havent gotten an alignment yet; i just got my rear suspension replaced on passenger side and havent gotten an alignment yet. i dont know if that would activate one of these codes but just sayin. Any advise on what to do?
