Alignment / tire wear issue
Old Jun 16, 2007 | 07:05 AM
RAWONE's Avatar
Default Alignment / tire wear issue
Hello all, newbie here. First post.
I have an 04 S4 with about 53k on it and owned since new. It has always had a front tire wear issue on the inside of the front passenger wheel. Dealer has said alignment OK but has gotten so bad, steel belts are showing on inside edge and outside edge almost new! Now doing it on both front tires. The wear is a gradual taper from outside to inside with the belts showing on the very corner...almost sidewall! All is bone stock and never any accidents. Not apparently rubbing on anything either. Any thoughts and help would be appreciated.
Old Jun 16, 2007 | 08:59 AM
techbod's Avatar
Default RE: Alignment / tire wear issue
have you had any damage to the front end?? have you altered the suspention? fitted wheels with the wrong offset,
ball joints/bearings and suspention cause this sort of thing.
edit: worth a read
http://images.google.co.uk/imgres?im...%3Den%26sa%3DN
fireman9585
May 19, 2010 08:25 AM
gtsboi329
Sep 1, 2009 08:11 PM
fireman9585
Jan 24, 2008 04:34 PM
dcdesign2000
Nov 9, 2006 12:17 AM
seaurchin99
May 26, 2005 11:39 PM
