Assistance Please..Strange noise after valve cover gasket replace
If the noise wasn't present before the repair(s) then something has obviously gone wrong as a result of the repair(s).
Remove the valve cover of the side with the most noise and check everything...you'll
most likely find the culprit.
That should be the first step, regardless. Because this is the only thing
that has changed since before the noise became apparent.
Grabbed a mechanics stethoscope and listened to both drivers and passenger side of the valve covers. They both sounded normal under all conditions. The noise seams to be coming from lower and further behind the engine. I could not hear anything to locate the noise. Any other ideas.
Noise is there at idle (temp independent) when the engine is reved, and at acceleration. constant RPM noise is gone.
Exhaust Leak...
Noise was the gasket on the secondary Air Injector on passenger side. Gasket was on bottom but was rotated and not on the top. New gasket no noise. New issue is a strange noise on the secondary air injector for cold starts and code:
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
P1411 - 35-00 - -
