Boost cotroller for my '01 Audi S4?
Old Jan 24, 2007 | 04:10 PM
2k S4's Avatar
Default RE: Boost cotroller for my '01 Audi S4?
ORIGINAL: Audi S4 BiturboBeast
Will do, I'll post as I learn. I have a slight lag on my take off but I'm pretty sure its a small boost leak. No biggy though, its running great. So far I've done a Front Mount IC, Bypass valve upgrades, Cold-air intake, and chip tuned it. I'm putting out about 325hp but have yet to dyno.
FIX THE BOOST LEAK, FIX THE BOOST LEAK!
It will kill your turbo's. Check the TBB, and your DV valves.
How do you know how much HP you have, if the car hasn't been on the dyno?
Yes, we have an N75 valve. I think we all know about it.
However, people do add MBC in parallel with the N75. I have even seen a 2 stage MBC hooked up.
It will not help with boost taper at all, just smooth out boost spikes, usually only on K04 cars.
But your MBC money into finding out where that boost leak is. There should be no turbo lag on your car unless the FMIC is to big, & you have to big/length of piping.
Old Jan 24, 2007 | 04:11 PM
ThePapaCMan's Avatar
No, I don't really have four boost controllers. I was being sarcastic
Old Jan 24, 2007 | 04:56 PM
mattr7786's Avatar
i agree with 2ks4 100% cause the turbo leak no matter how small it is ..is no good at all what so ever..sooner or later it will be a blown turbo...!! get that fixed first...
the papacman
that **** is funny i was thinking to myself that is not possible... and if you did havefourMBC's on i was gonna tell you to get off of the forum and stop givingpointers to do so..haha that **** is fo funny!!!!!!!!!!!!!!
Old Jun 13, 2007 | 01:55 PM
ahwest's Avatar
Member
how do i add the MBC in parallel to the N75? i'm a visual person it will be very helpful if some one can post a picture of how the vac hose should be connected the MBC parallel to the N75 valve.
thanks~
Old Jun 13, 2007 | 03:36 PM
2k S4's Avatar
ORIGINAL: ahwest
thanks~
Do a search, we have talked about it in lenght
Old Jun 13, 2007 | 03:50 PM
ahwest's Avatar
Member
yea i found that pic but im still confused about the connection.
Do i make a tee connector from the original boost pressure vaccum hose from the turboand connect to the MBC and the N75? and then also make a t-connector to connect the N75 and MBC and to the boost pressure vaccum hose to the wastegate?
thanks
Old Jun 13, 2007 | 05:02 PM
2k S4's Avatar
ORIGINAL: ahwest
Do i make a tee connector from the original boost pressure vaccum hose from the turbo and connect to the MBC and the N75? and then also make a t-connector to connect the N75 and MBC and to the boost pressure vaccum hose to the wastegate?
Why are you adding a MBC? You know it will NOT allow more boost? It just there to help boost surging, & usually only on K04 cars.
Yea, you use 2 T's.
Old Jun 13, 2007 | 06:35 PM
  #18
ahwest's Avatar
Member
the reason im adding the MBC its because when i go into GIAC chip mode, it boost spikes at around 24psi! maybe my leaky valve cover gasket causes that? but im changing the gasket very soon.
Old Jun 13, 2007 | 08:54 PM
  #19
2k S4's Avatar
ORIGINAL: ahwest
You need to log block 115 & see what the requested vs actual is. My guess is the car is not requesting that much, unless you have the K04 race file. My bet is on a bad/going N75 & maybe a leaking wastegate accuator.
Old Jun 13, 2007 | 09:52 PM
  #20
ahwest's Avatar
Member
will I get a check engine light with a bad N75 valve? should i just replace the bad N75 with a MBC?
