Brake Question
So I just installed Zimmerman Crossdrilled rotors with PBR ceramic pads in the front, the stopping power is excellent aside from one problem. The brakes squeek uncontrollably almost constant.. what paste or anti squeek gel or whatnot can I buy to put on my pads or rotors and where can Iget it from?
Also, car is a 2000 S4 if that makes any difference at all.
Ceramic pads squeak.
It helps if you sand down the leading edges of the pads, so the middle will contact first. Then just put "anti-squeal" on the pads around all the edges where it touches the caliper carrier & piston. Also lube the guide pins.
