Brake Question
Old Mar 19, 2007 | 05:40 PM
Barrington's Avatar
Default Brake Question
So I just installed Zimmerman Crossdrilled rotors with PBR ceramic pads in the front, the stopping power is excellent aside from one problem. The brakes squeek uncontrollably almost constant.. what paste or anti squeek gel or whatnot can I buy to put on my pads or rotors and where can Iget it from?
Also, car is a 2000 S4 if that makes any difference at all.
Old Mar 19, 2007 | 05:49 PM
ThePapaCMan's Avatar
Default RE: Brake Question
The sqeeking should go away after awhile. I had the same problem. Once everything sets up after a week or so you should be golden!
Old Mar 19, 2007 | 08:52 PM
Woodhead2k's Avatar
Yea new breaks will generally squeak for a few days if not longer until you break them in. Try doing a few break checks to speed up the process.
Old Mar 19, 2007 | 10:11 PM
GeilKyle2's Avatar
yeah when I put on the brembo's I tried all the brake quiet gels and everything, nothing would quiet them down, but after a week or so, silence
Old Mar 21, 2007 | 08:39 PM
Barrington's Avatar
it seems to be getting a little bit better, but i have almost 400 kilometers on the brakes and its still not gone, any insight on how long it takes?
Old Mar 22, 2007 | 03:48 PM
GeilKyle2's Avatar
If I remember correct is was atleast of week of a lot of hard stops
Old Mar 22, 2007 | 06:25 PM
2k S4's Avatar
Ceramic pads squeak.
It helps if you sand down the leading edges of the pads, so the middle will contact first. Then just put "anti-squeal" on the pads around all the edges where it touches the caliper carrier & piston. Also lube the guide pins.
Quattro_1.8t
Jun 10, 2008 08:37 PM
jayson161
Jan 21, 2008 03:02 AM
tyleryours
Jun 1, 2007 06:16 PM
cannon64
Jan 16, 2007 02:56 AM
Jeff
Apr 25, 2006 02:42 AM
