CEL Codes, help?
My friends S4 pulled up the following codes, hoped you guys could help me out:
Part No: 8D0 907 389 E Component: ABS/ESP Allrad D56 Coding: 04395 Shop # WSC 06435 2 Faults Found: 01435 - Brake Pressure Sensor 1 (G201) - 35-10 - - Intermittent 005265 - Brake Light Switch-F - 27 - 10 - Implausible Signal - Intermittent |
Ross Tech Wiki told me to try the following solutions. How exactly do I perform these? We don't have a repair manual for this car.
Perform Basic Setting * Check/Replace Brake Pedal Switch (F) o See Measuring Blocks * Check/Replace Brake Pressure Sensor 1 (G201) o ABS Hydraulic Unit (N55) may need to replaced o Perform Brake Pressure Sensor 1 (G201) Basic Setting o Replace Brake Electronics Control Module (J104) |
| All times are GMT -4. The time now is 04:00 AM. |
