Control Arms & Bushings
All my front steering bushings are worn and my front left lower control arm is bent. Now if heard that this is a common problem with S4's yes/no? and all the shops around here are telling me like 2000$+ for some kit. Does anyone know where i can get these parts for less?
NO, BENDING IS NOT NORMAL. Bushing wearing out & ball joints are. Febi/bilstein are good & the meyle
http://www.blauparts.com/audi/audi_c...arms_kit.shtml
In the faq there are a couple of places that sell the kits just make sure you get the S4 instead of the A4, it will work, but the bushings are softer. There are about $500 for the full kit, & about 6hrs to install both sides, then you need an alignment.
does the bending of a control arm sound normal to you? no! 2k for an install, where are you located so i can rape you out of your money. 500 tops for a febi bilstien kit and maybe 700 for an install. however, if i were you, just do it yourself, but no one seems capable of doing that now a days. hence the reason why people like you seemed to get ripped off then bitch about it on the forums. research and try using the search function sometime.
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
